3G Fails using browser/ Works running app
droidborg
Member
My MT is acting up with the typical 3g fail, GPS won't connect, (if it does, it usually won't find my location) static phone connection, and once the cell radio icon went to the X.
To get the 3G working I turn Data off and then back on again. I'll be able to load web pages for about 2 mins, sometimes less. then restart to surf again. WiFi Works flawlessly
If I run Netflix and watch a 1/2 hour tv show, 3G stays connected, even multiple shows.
The you tube app seams to maintain the service as well.
VM is sending a replacement, but I thought that I would share the experience. Odd it does that.
My MT started with its 3G failings since yesterday afternoon. The web browsers dont work, GPS, picture texts, nothing but some of my apps do, oddly enough. Twitter, FB, Yahoo email, Gmail, Youtube trending works and I can click on the videos and see the comments and suggestions but when I try to actually watch a video, thats when it wont play. Same with Netflix, the front page starts loading but the titles never show up. Shazam and Pandora dont work at all.
I called customer support and nothing they tried worked so they told me headquarters was going to call me with a solution later today (hopefully). Was a replacement the only solution they gave you?
