Ah that hard reset forgot about this thanks..!
I have to do something this battery drain is crazy bad..
I can sit there without using the phn @ all & look @ it every 1/2 hour or so & its draining up to 10% a hour with 0 use..
Kies just updated as well so hopefully something will change
Peace
EDIT : They must have changed the button config or something with the update cause I can not get my phn to boot into recovery console using that method..I have before & know how to use it so not sure whats happenin.. =\
EDIT AGAIN : disregard that last statement had a major brain fart & was forgetting to hold the home button haha
You wiped, then installed apps, then did the OTA? If you did that, you might of well have just installed the update on top of what you already had. You probably have an app installed or something that is conflicting with the update. Do another wipe and see if it'll fix the issue.
A clean install involves:
1) doing a hard reset back to factory defaults through Android Recovery Console (this involves wiping both internal and cache partitions and repattitioning them again)
2) download and install the update via OTA or Kies
3) doing another hard reset again
Then you start reinstalling the apps and restoring your data.
Unfortunately, if the update was applied successfully, you cannot revert back to the previous version by 'normal' means. Not even a emergency firmware recovery through Kies will allow it.
The ONLY alternative you have (without tripping the flash counter and voiding warranty) is to use ODIN and the CARRIER'S OFFICIAL STOCK FIRMWARE 4.1.1. Basically you will have ODIN flash the stock firmware to your phone. But this method can wipe your data in the process. So make proper backups before attempting this. You can probably find these at XDA. If the counter is tripped, there is a way of resetting it. But not too sure about that method. Again, XDA should have a solution.
I think the update got rid of them. The reason why it was probably still present in the device was because it was residual files from the previous vesion. I don't have the samples anymore which I'm quite happy about. That was one of the first things I got rid of when I got my Note anyways. Don't need them.![]()
do i need to re download the 4.1.2 after hard reset
or since its there then no point?
If your device was successfully flashed to 4.1.2, there will be no more OTA/Kies updates to download/install. You can only do a re-download/reinstall if the original update failed and an emergency firmware recovery was required (since the phone will be reverted back to the previous revision before the update).
The reason for doing another hard reset after the install is to remove trace residual files from the initial update/install that may still be present. This primes your device and ensures that most residual files are gone.
Now, doing another hard reset (after all this) depends on the user. I, personally, like to 'flush' my system every 3-6 months to keep it in 'tip-top' shape. Reason is, over time, I can cram too much 'junk' into it and really need to clean it out. Spring cleaning for the phone you might say.
That's why a hard reset never bothers me as others because I am so used to doing them so often.
