4 apps to enhance camera/multimedia on X10
powerkiter
Android Expert
OK so there are a few market apps for new camera like Vignette but you need to pay for all the options and I brought Vignette and was not impressed by it at all and still use the stock camera app.
Anyway here are 3 free apps I have found that go halfway to making the X10 a better camera/media phone...
First off.
Andropan:
A phone which cant do a simple 3 picture panoramic picture seems odd to me as my old SE K750i from 07 could do it and then my LG KC910.
This app not only does a simple 3 picture stitch it also does huge multi stitches like 4x4 so thats 16 images stitched into a huge panoramic image!
Plus if you do a 360 deg shoot it will not only stitch all the images it will even launch a program that creates a virtual 360 deg pan-able photo by sliding it round on the screen!
screen
chart
Next...
Photoshop express by Adobe
No need for a screen shot it does exactly what it says on the tin! Plus its adobe if I forgot to mention it :)
chart
Next...
Camera Illusions
This is more a stand alone camera app but its free and gives you some great lens effects and frames and boarders. You can get the full app but the QR code is for the free version that I have.
screen
chart
OK this next one is not needed but a nice add on to the multimedia side of things.
Printshare
It allows you to link your phone to your pc via a program you need to install on your pc or the paid for version allows you to link via wifi to wifi enabled printers and then print any number of file types direct from phone to printer!
screen
screen
chart
Hope some of them help enhance the multimedia side of the phone for some of you :)
EDIT: ALL APPS ARE FROM THE ANDROID MARKET :D
also dont spose u would kno wot program i would need for the PC ;-)
Notsure if the wink is sarcasm but yeah I should have said:
"You need to register with Printshare and you get an email with a user name and password and you go to their site via your pc and download the program from there" :D
no mate no sarcasm was ment :eek:
TBH i was jus being bone idle, and wanted my cake and eat it :D
oh and thankyou......
Would you like me to come round and turn your barcode scanner on for you?
I would say "Would you like me to google that for" you but the QR code is there you lazy bugger lmao :D
haha,
Well i got that for but if u wouldnt mind coming round to set/download the printershare software for me mate that be great, ill chuck a cupper in :D:D;)
Andropan opened for me the first time, but now FCs every time I open it. Oddly, all I did on first run was open the preferences and look them over (never changed anything).
Sh1t, same problem saltorio. FC from first time, couldnt even open it..... Mnnnnn pity, sounds like an awesome app...
andropan works fine with me...just have to toy with it...just wondering why it takes me to the latitude app...
