Help 4 double same system apps named "phone"
M_ahmed
i say in my andriod apps 4 double same apps named "Phone"
one of them appear once i open my apps from setting and the other there apps appears when I enble option "show system apps"
- my phone is Note 10 plus with 2 sims in the same time
- my system is Andriod 10
please advice if it is hacking apps or not
only because on the other same phones I found only three same apps
sorry for wasting your time sir
you are not wasting my time....not at all.
my guess is that you have 2 sims cards thus showing an extra phone application.
i think you are fine. the idea of hacking is not to be noticed. just because something does not look right to you, does not necessarily mean you are hacked. i think you should not be concerned with this.
