Hi guys
I have seen a brand new Galaxy S5 that I wish to buy but am confused if it's authentic or not...when I took off the battery what I saw was SM-G900V made in China but when I switched on the phone and went to Settings then About I noticed it is instead SM-G900F and the network band supports LTE showing me a 4G at the top of the screen after inserting my Nexttel SIM card. please help
thanks in advance
Thanks IA, and thanks for the timely nature of your reply! Lovely ideas over there at AT&T, eh? The good news is I have a direction to move in; I only wish we weren't quite as tied to AT&T as we are. Thanks again.No. I'm afraid that the AT&T model, G900A, running the latest Lollipop firmware release and the two prior to it, is completely un-rootable, thanks to AT&T's mega locked down bootloader. In fact, the model has been un-rootable for over a year now, since the release of Android 4.4.4. AT&T just prevented downgrading back to Android 4.4.2 in their latest releases, to prevent rooting.
Thanks again ironass - just to belabor the point and make sure I've got it right: if I'm interested in rooting a 900A (or V), and using AT&T or Verizon, I need to be sure it's running Android 4.2.2 or earlier, and then, if I find one, I need to be sure I don't get any OTA updates forced on me before I root it and flash a custom ROM...yes no?
Hi guys...I got a Galaxy S5 SM-G900H updated to Lollipop...I wish to ask if I can downgrade the OS back to 4.4.2 and root it then later upgrade back to lollipop via OTA updates and even further to Marshmallow if it hits the S5 device
You can root the G900A on Android 4.4.2 but if it has Android 4.4.4, you will be able to downgrade to 4.4.2 and root. After that... you're stuffed on later Lollipop firmwares! If a phone has got 4.4.2 or 4.4.4 in spite of the forced AT&T updates, then it's probably rooted anyway as that is the only way to escape them.
Well, hmmm... I expect the likelihood of finding a New Old Stock 900A running Android 4.4 or older is pretty skinny and getting more so; thinking I need to shift my attention to finding a GS5 variant New In The Box that is *NOT* a Verizon or AT&T model, but that *DOES* receive AT&Ts LTE wave lengths...
Located a New In Box SM-G900T - looks like that will fill my bill. Thanks again ironass for your time and attention, and thanks to WillMyPhoneWork.net!
Plus... T-Mobile (USA) has just received another update to its Android 5.1.1 firmware.
You don't have to downgrade the G900H to root it... it's not an AT&T or Verizon phone model. Rooted phones do not receive OTA or Kies updates and need to be updated manually. See #1.11.
thanks Ironass for your always timely responses...my doubts are cleared now...but I also wish to ask if it is certain for Android Marshmellow update to affect the Galaxy S5 device
I cannot guarantee that all 41 models mentioned in post #1 will receive Android 6.0, Marshmallow.
Hi. I got a new s5 900A (ATT) unlocked, running android 4.4.2. How do I upgrade it to Lolipop? Which is the last version available? Regards, Saul
