Help 4G Icon Stays On When Wi-Fi is On
carlosd24
Does anybody else have this happening?
When I turn on the Wi-Fi and connect my phone to a network, the 4G icon stays on, but when I go check to see if there's a 4G MAC Address, it says unavailable.
Does this mean the 4G icon being there means that the 4G is still on even though I'm on Wi-Fi? Is it a bug?
Here's a screenshot.
This happens to me when I turn on my phone. All I do is disable both data and Wi-Fi and then enable them again. This solves it
That's not normal bro because once your WiFi is on it should automatically turn off your 4g cuz your not using your data from your phone.
I reset the phone to factory settings with CWM and the problem is gone. Must've been a little bug.
Thanks for your input!
