Root 4g is going
caguayote
Member
when i upgrade to zve i got 4g signal all the time but i decide to try galaxy s3 and now i can make calls but i can not connect to the internet because not network apears i also want to say that after a flash galaxy rom i saw the bluetooth fix and a flas it then is when the problem starts the bluetooth fix from everslayed tanku guys for all the help
Yes it sounds like you flashed the wrong one and very confused that it worked for u cause it shouldn't boot up or if it bootlooped on you . But check to see that u have the latest zve .
