I'm getting 5.3mbps down in flroida.
Not strange because CDMA uses the transmission of 3 towers simultaneously. Meaning perhaps you didn't have all 3 towers at once, and only had 1 or 2. That would easily effect your speed in the same spot.
hey guys, im in LA and i only have 2.3 of speed....what is the 4g real speed? around 20?
4G speeds are casified 100MB to 1GB.
what the current carriers are calling 4G is not really 4G, they call it 4G because its faster than 3G speeds.
The Galaxy indulge is capable of 21MB but speeds will all depend on the cell tower your connected to and speed limits that Metro puts in place.
I'm doing two tests in the same place. Saugus, Mass. For some reason it says Dallas, TX is closest server to me but thats a lie.
Test one - DL 1216 kbps, UL 1378kbps
Test 2 (3 minutes later) - DL 531 kbps, UL 1270 kbps
It was pretty awkward how much it jumped. I literally turned on the LTE then downloaded speed test and ran it for the first number. I came here to write it and ran the second test and it was slow as hell after.
I get roughly 2.5MB/s down and 2MB/s up using the speedtest.net app..
I don't know if it's just me or not, but it shows the closest server to me being Dallas, when I'm in Philly.. I dunno why that is, but it's that way with GPS on or off.. Any suggestions?
