no1lives4ever
I searched the forum and failed to find a similar topic... if its out there then please point me in the right direction.
So I am a total noob when it comes to tech... please bear with me as blunder my way through this.
I have an AT&T Note i-717 that I unlocked (for T-Mobile), installed ICS, rooted using (ODIN) NoteRoot, then backed it up with Clockwork.
Prior to rooting I had EDGE on my phone and was able to make calls, after rooting and installing clockwork I had lost my network. I thought OK... if I flash one of the suggested radios then I will get my connection back. Right? Nope.
I have tried VKL1, KID, and icsblaze. After all that it still says NO SIM and will not get a network of any kind...
Did I brick it or is there a fix?
Thank you!
Thank you!
