Help 64GB Micro SD Compatible if formatted to fat32?
Hey all, Galaxy S owner (bell) here. I have the latest update of the firmware too, which is a step below chocolate sandwhich or whatever. So I am wondering if it's at all possible if you can get a 64 GB micro sd card to work in a Galaxy S if you simply format it to Fat32, i heard somewhere that doing so actually works. I am trying to get past 32 GB's, well which I have not ordered that card yet to see if this is possible first. Thanks in advance, cheers.
Okay I guess some people don't care about this but, I have confirmed to find that the Motorola Droid Bionic only supports 32GB's of expansion memory card space, and an owner of one has confirmed that a Sandisk 64gb microSDXC is working in his phone despite those "limitations".
My sources of this information are here:
Motorola Droid Bionic Specs:
Motorola*Smartphone*Droid Bionic XT865 Memory Ram Upgrade - 100% Compatibility Guaranteed at MrMemory.co.uk
(text search: maximum memory)
http://androidforums.com/android-lounge/394162-64gb-micro-sd-work-phone.html
(text search "Sandisk 64gb microSDXC")
These cards are expensive on Ebay:
1
64gb microSDXC | eBay
Cheapest price is like $148 CAD plus tax and shipping.
That is cheaper though, with the same card going for $192 CAD on FontierPC.com
Buy SanDisk Mobile Ultra 64 GB microSD Extended Capacity (microSDXC) - 1 Card - SDSDQY-064G-A11A at FrontierPC.com in Canada
Just for everyones information.
Oh and the 32GB micro SD cards are going for around $30-$50 on Ebay so I guess the better way to go is the garanteed way.
