Good idea, I'm not sure if my phone which is the Z1C will support the on the go USB adapter cable as it isn't showing in the compatible list.Do you have a USB OTG adapter cable for the phone. Fastest easiest way, hook a card reader to the OTG, put the new SD in it, and copy everything one to the other using a file browser. You can use a PC as well, and use that to copy from one SD to the other, again with a card reader. That's what I did when I changed to a new larger SD.
I would like help in picking the fastest and reliable data transfer
also is it best to pick a Sony brand of card?
Will it be fine for UHS speed class 3?
Will my Sony Xperia Z1C work with this microSD card?
Do you mean the Z1C?A UHS-3 card will work fine in the Z3C, yes.
Yup, you should have no problem with that one either.
This is the one I have purchased, and want to really know if it'll be compatible for reading and writing etc on my Sony Xperia Z1C.Will my Sony Xperia Z1C work with this microSD card? details shown below:
SanDisk Extreme 64 GB up to 90MB/s Class 10 V30 FFP microSDXC Memory Card with SD Adapter
