Help 64gb SD Card...
Hi,
im having troubles with a 64gb sandisk class 10 sd card in my galaxy s3...
i the only way i can get it to work is if i format it to FAT32 on my pc and then put it in the phone, otherwise it won't even recognise it...
i tried formatting if on the phone itself (after a fat32 format on the pc) and it would not remount the sd card and just said it was blank in the drop down menu...
anyone know what the issue might be here? it works as fat32 pc formatted but no other formats, and it can't even do it itself
cheers!
Larsson
