Root 95MB/s SD for SWAP?
LaimisV
Hi,
I can see that my Samsung Galaxy S not enough memory for applications.
Is it good idea to use fast sd card for SWAP? I'm thinking about 256-512M swap file on Sandisk-8GB-Extreme-Pro-UHS1-MicroSD-Micro-SDHC-Memory-Card-TF-95MB
Can I reach max speed with Samsung Galaxy S I9000 and newest cyanogen mod?
Hi,
No, the only device that supports full UHS1 speeds as far as I know is the i9500/Galaxy S4 with Exynos, probably other devices using Exynos 5 Octa support it as-well but definitely not the i9000.
My Galaxy S4 (i9505) doesn't even support UHS1 transfer speeds, best you will get is around 10MB/s
