SIKESR
so i had just finish installing the new extended battery(red & yellow) & after the battery ran down to shut off, i connect the charger(phone off) & leave it on till it was fully charged..so as i turn the phone on everything is cool, until right after the glaring samsung logo the screen turns black & does this little vibration..& it would do the little vibration every couple seconds..so i tried shutting the phone off holding the power button & nothing worked,then i took the battery off manually & put the original back in...so it booted it just fine,but it had reset itself,,,then i tried downloading the google maps update and a message appeared saying i had insuffient memory..i checked my internal memory & turned out that i had 00.0b internal memory...so i wanna know what can i do to get my memory back to the phone???? Please help...phone is practically useless without the memory...cant download apps,cant send pic/vid messages or hold stock apps on too long before foreclose occurs
