A few minor issues with USB connection
plummeh
I have a Compaq (HP NC6400) laptop with Windows XP professional. I appear to be having some problems connecting the phone to my laptop, both mine and a relaives Dell Vostro don't find the HTC Hero, all that comes up in My Computer is "Removable Disc Drive (F:)" When I double click that it asks me to insert a disc.
If there is anyone who is/have suffered from this problem who can share some advice it would be much appreciated.
Thanks in advance.
Are you "mounting" the Hero, so it's viewable on your PC/laptop?
Connect the Hero with the USB cable and you should see a USB icon in the status bar at the top of the Hero screen.
If you drag the screen down (put your finger at the top of the screen and slide it down), this will open Notifications. You can then press the USB connection option and this will "mount" the unit and make it accessible via your PC/laptop.
Chegs.
Thanks for the prompt reply,
I've followed the steps you've provided to no avail when I select "Mount" on the phone nothing appears?
Any other suggestions?
Thanks.
Yes I have HTC Sync installed and now when I plug my phone in it's not showing any notifications so I cannot mount the phone to USB anymore.
Tried in all usb ports again to no avail. I've managed to get the phone to prompt me whether to mount the phone to usb but when I mount it I still can't see the phone as a drive. Any other ideas?
I found when i first connected the phone to a usb port it took a long time to be seen by the computer for the first use. Turn on the phone and the computer. Plug the phone in to the USB port and come back in half and hour. Even if it looks like its finished installing there seems to be somthing going on still.
