The instructions say to charge the 1750mah battery 2-3 hours after the green light comes on. Does this do anything for the Incredible, or is this instruction just for other phones? Also, you know how charging the stock battery full with the phone turned off stops the battery from dropping down to 90% extremely fast (after unplug of course)? Do you need to do this with the 1750mah battery as well? Does charging the phone while off with this battery have any benefits, other than charging faster? Finally, the instructions say that it takes 5-6 full charge cycles before the full effects of the batteyr kicks in. Was this estimate correct, or does it take more/less charge cycles, in your experience? Thanks a bunch guys!
