Masquerain
Some time next week I will be getting a new phone, and I was looking at getting the Droid 2 global, but first I have a few questions that I have not been able to find the answer to.
1. I currently have an enV Touch. It is very scratched up from me dropping before I purchased a case for it. But after I got one, the phone became 10 times more scratched from the inside of the case. I don't want that to happen to my new phone, does anyone know of a brand of case for the D2G that will not scratch the inside but will also protect it well?
2. I know that there is a difference in the LED Flash placement on the D2 and the D2G which causes a there to be a separate type of case for each, but are other accessories interchangeable between the two?
3. I know that the D2G has a 1.2 GHz processor, and the regular D2 and the R2D2 only have a 1 GHz processor. I would like to get the white version of the D2G, but they currently do not make an extended battery in the white. I have heard that you can purchase one for the R2D2 and there is little difference in appearance, but will having a battery that was made for a phone with a smaller processor somehow cause problems?
4. Other than the difference in the processor size, and the fact that one is global, is there any other important difference between the Droid 2 and the Droid 2 Global?
5. With the iPhone and such, there is a way to change the icons that are set at the bottom and always at hand, no matter which window you are on, is that option available on the D2G? Or am I stuck with contacts, phone, and the third one (I can't remember what it is lol).
6. While at the Verizon store, I played around with setting the short cut keys (ex. press 'A' to open Text Messaging). But when I went and tried out the letter I had pressed, it brought up the Google search instead of what I had set it at. Is that option actually available and works? Or is there something else you have to do to get it to work (such as disable the Google search thing)?
Okay, all done
Thanks for any help that anyone can provide
Okay, all done
