Help A 'few' questions
GeekClass
1. Longshot, but this is for those with the dock and OS X.
Does OS X (whatever app you're using) recognize the internal storage in your Transformer tablet when docked?
Does OS X recognize the microSD in your TF tablet when docked?
Does OS X recognize the card you're using in your keyboard dock?
Does XNJB work?
2. After the latest TF and keyboard update from Asus, have you had any problems?
3. How is the typing in apps like Polaris, DocstoGo, and other installed apps? Any lag?
4. How is the typing in website comment forms (like this forum)? Any lag?
5. What's the highest SD/microSD/SDXC card you've tried and did it work? And has anyone tried an SDXC card?
6. I'm not the biggest fan of laptops in general, though I've gotten use to my 13.3 Macbook and its chiclet keyboard (and may even like it). How's the typing experience on the Asus keyboard after an hour or so, or two thousand plus words? For those who like smaller laptops (13 inch and below), can you see the keyboard itself replacing your laptop/netbook?
7. How is the MyCloud music player? I'm guessing the organization and presentation is a bit crap, but does it work consistently?
Thanks for any answers!
