A frequent problem
VXKX1933
It is necessaryu to have a firm procedure for transferring data from one SD card to another. if somebody could produce a standardised process it will help a lot for a lot of people.
Not sure I understand your question? You can just use whatever process is easier for you.
But welcome to the forums :)
I mean that I do not know how to transfer all my data in an 8 GB SD to a new blank 32GB SD.
Hope I made my self clear enough.
K.V.
The easiest way is to put both SD cards into a computer and just copy and paste the files between the two. Or if your computer only has one SD card slot you can copy all the files to the computer... Then put the new SD card in the computer and copy all the files to it.
If your computer doesn't have an SD card slot, you can use the USB cable that came with the phone to connect it to your computer.
