Root A how to repair your battery
llib01
OK first off this is for a battery that
A: got slightly wet
B: or doesn't want to charge and shows a yellow battery symbol
OK what you do is carefully remove the sticker label
Then you are going to see a black square circuit paper connect to battery terminal carefully unstick it from battery with out breaking the connection then slip a paper between it and battery tape it back together and your done.
Will add pics soon good luck tested and worked by me
