Eh well hello, i must be the unluckiest man in history to go through such problem
To cut a long story short and make it easy for you to read and reply, ill sum up my problem.
-Unofficial Chinese tablet
-Rooted, No custom kernels / anything else and no clockwork etc. .
- Tried to install drivers for a tweaking app, tablet shut off as soon as i clicked install drivers.
- Tablet stuck on its boot logo.
-Holding down buttons lead to a dead android with an exclamation mark on top.
-Somehow got my self to recovery options by holding power + clicking the volume down once while the dead android is showing.
-Factory resetted the tablet.
- Problem persisting, Still stuck on logo
- Can't go into download mode because = Dead android with exc. mark / buttonless tab.
-Terribly Frustrated
So basically i'm out of options here all i have accessible is the recovery menu and 0 to no backups, accessing the tab from pc is impossible due to the problems above, i have no idea what i should do.
P.S, i spent 5 hours searching for a solution for this mess, i cannot find the answer anywhere , Do not hesitate to reply if you have any sort of knowledge of this situation.
Thank you alot.
Thank you alot.
