hollowpoint
At this very moment I'm still waiting for my previous/existing phone number from a different provider to be switched over to my newly purchased Evo 4G.
When the phone arrived I got it turned on and just started checking out all the bells and whistles loaded onto this smart phone.
I must have inadvertently tapped the twitter App because ever since then I've had a dialog box in the center of my view screen stating, "You are not signed in. Tap to start using twitter."
Like most of you folks, I'll never use the vast majority of the pre-loaded apps that come with these smart phones. In my case, this twitter application is one of the apps that will never get used. I got this cell phone to send and receive phone calls and to surf the internet on occasion.
My question is; regarding this dialog box in the center of my view screen. How do I remove it? There seems to be no "Cancel" option. Will I have to create an account for this twitter app just to get it the heck off my start up screen?
Thanks for your help.
HollowPoint
HollowPoint
