no_1_u_know
Howdy Folks,
I'm a little confused, as I try to follow the Incredible 2 Rooting Guide
http://androidforums.com/incredible-2-all-things-root/520738-incredible-2-all-things-root-guide.html
What confuses me is that the guide has two paths:
The problem is that I do not match either condition. I have:
Android V: 2.3.4 and SW# 6.04.605.07
Guessing I need to roll back the Android V to 2.3.3, but not sure which process/tools to use.
Anyone?
Thanks very much...
no_1_u_know
Check your software number in Settings> About > Software information > Software number. If it's 6.01.605.05 710RD use:
[guide] How to manually downgrade firmware build 6.01.605.05
Comprehensive S-Off/Root Methods for all firmware versions (no bootloops on 6.01.605.05 firmware!)
[guide] unlock with htcdev
If it's 5.10.605.9 you can start here:
Downgrade Gingerbread 2.3.4 to rootable version 2.3.3
Anyone?
Thanks very much...
no_1_u_know
