Help A nightmare of a touchscreen problem!!!
Hello all!
I have a Sensation XE, I had an issue with the stock battery (it turning off at around the 60% - 40% area). Tried to sort that out by, s-off followed by superwipe, flashing firmware and darkforest 5.1.5 rom.
Turned out the actual battery was this issue after I bought the Anker 1900mah battery. Everything was fine until yesterday.
Now the touch screen doesnt respond 99% of the time, if it does.. it is only for a few swipes after i restart the phone.
But the odd thing is.. when I use 4ext recovery touch, the touch screen works just fine!!! The issue only every arises when I normally boot the phone.
I have tried superwiping the phone so many times, using every tool/format/wipe option from the 4ext recovery followed by installing the latest darkforest rom or the android revolution.
So I don't thing its the digitizer, I've tried fully charging / discharging both batteries using the official htc charger. I've played around with the grounding pin. No luck.
I'm about to try insertcoin rom.
Anyone had this problem in this much depth?
I'm so close to throwing it at a wall and buying the htc one, but being in Australia, its stupidly expensive.
Thanks in advance
Jake
