Taskellusaf
Member
Has anyone noticed any problems.... Mine seems to be the battery... I can kill mine in about 10 hours may go to inter may go to internet browsing and screen time..
Download the gsam battery monitor (formerly the badass battery monitor) and see if things are draining your battery in the background. And it is possible the battery is bad but check it out first. Good luck.
Was your phone brand new when you sent it back? No it wasn't. So why would you expect them to Send you a brand new one in place of a used one, business doesn't work that way. And CLNR phones usually don't have any problems and you won't even know it's refurbished. If there's a problem call and send it back and you have another one the next day.
For me the replacements have worked better than my original phone half the time. If you think you battery is defective then call and tell them that.
. You may get one someone used for a day and returned, or you may get one that's a pos. One of the reasons i don't buy insurance is because of the refurb idea. In my experience (one of top 4 wireless networks), the refurbs are complete garbage/problematic.This is what ticks me off. I bought a brand new phone yet they wanna send me a used one. Total bs.
Same here. I went thru 5 phones in a in a row, and finally told them that if they sent me one more defective phone, I would buy out my contract, and get service elseware. They gave me a new phone.Caesars, not every one... but I've got a lot of duds trying to test for functionality that was never resolved.
The original phone had conectivity issues. They sent a replacement that the back wasnt attached, and the screen wouldnt turn on. The next one, the bottom 4 soft keys would randomly light up, the left 2 separate from the right 2, and at random times. #3 was stuck on an endless boot cycle, #4 had a horrible speaker cracking sound. and the kevlar backing had a huge bubble under it, and #5 was missing the power button......so Im not sure if it worked propperly or not.What issues did you specifically have? I love my phone but have a few issues that do not jive with what VZW is advertising, and it's pissing me off. I might just do this same thing, but actually test some of these features in the other carrier stores.
You might notice that an app to monitor your battery actually uses your battery.
I've got a bunch of CLN's over time from VZW, it's hit or miss.
But yeah, basically anything and everything uses power to some extent.
