A Speech to Text (Notes) Application for Android?
Can anyone suggest a good application that will allow me to speak a "note" into my android phone?
There's plenty of apps that do speech to text, but then either offer me the choice of emailing or texting it, the best I've found so far will allow me to cut and paste it into a note, but there's so many annoying stages I might as well just type the note in the first place.
So no texting or emailing apps, but just something that's as simple as
a) press button
b) speak note "buy eggs, bacon, cheese, bread and cucumbers"
c) save as a note to be read again when I get to the shops
Thanks!
Many thanks for the reply, I downloaded that App, but all I could get it to do was to record a voice memo, not convert voice to speech - am I not using this correctly or is this a memo taker and not speech to text application?
Thanks
You have to choose a new text note not a voice note. When you choose text note, your keyboard will pop up and then push the little microphone on the keyboard. Then you can speak a note and it will be transcribed into text.
Evernote will do this click new note then scrool the top over to the right and tap the check list feature box now tap microphone say item then tap enter key then repeat for each item very easy and works flawless as you get the item you just check them off.I have Evernote and catch notes and use theme numerous times a day.Hope i was able to help.
