shaunjohn
1) download these 2 files, (diag scripts, samsung diag drivers) and get CDMA WS , if you flash phones you should have the full, the cracked will work too
2) install samsung drivers
3) download script manager from google play
4) put diag scripts on sd card
5) run script manager and locate diag scripts
6) choose diag.sh and click on su, and execute script
7) go to device manager on computer and after drivers install take note of of the COM port that SAMSUNG Mobile USB Serial Port says
8) open CDMA WS and select com port from step 7 and connect
9) go to security tab, then the password box, drop down to Samsung default, hit send
10) then your SPC/MSL will appear in the spc box in the same tab
https://www.dropbox.com/s/kfetqlclp5pfwqv/Samsung_Generic_Driver.exe
https://www.dropbox.com/s/12k3o19otv6hyny/GS3_Diag_Mode.zip
I just now realize, the purpose was to find an unrooted way to get MSL/SPC, to run the scripts it takes root. Anyways, I guess if you want another way to find your SPC have at it
