Help A500 help please...
gsavage
I'm new to the tablet world, I recently got the Acer a500 and fell in love with it, my problem is not only fact the Hero of Sparta cant be removed at all and it just sit there teasing me, and when I called acer Tier2 they talked to me like I should know what I'm doing:mad:. So here is my issue that I would love to have some help, direction or instruction:
I purchased a 8g micro sd card for games and such but when I attempt to download the game, it asks internal memory or sd memory. I select sd memory but it still goes to internal. so thru my extensive search on this and other forums I found I needed a file manager. so I proceeded to download Es File Manager. with of course no idea how to use it, according to tier2 I sould know how to useit and its a third party app, figure it out. sooo please, if there is any chance of fixing this I would really appreciate the advice.
Welcome to the Android Forums!
Moving your thread to the ACER Iconia A500 forum to help get you the answers that you seek... ;)
As far as I know apps/games cannot be moved to the external sd card,they will be downloaded to internal memory. I have tried and was unsuccessful at it. But i figured with 16gb built in and my 32gb card i was good to go anyway. I am able to move apps on my 7" galaxy tab but i think that's cause it isn't running honeycomb. I think i read somewhere it had to do with HC on the acer not allowing these things to be moved.
Someone correct me if I'm wrong. If it can be done I would like to know for the heck of it.
I got what your sayin, but just the three I've downloaded seems to slowdown the tablet. any other ideas? oh and i cleared the cashe history too.
