Hello All.
My Acer A500 is five days young. I am educated in computing, so I know what I'm talking about and you may be as technical as you'd like in the replies.
The issue I'm having appears to be a router issue, but I could be wrong.
Got my A500 shipped to my work, and connected to work Wifi without an issue. Used all day at work.
Got home, and could see my (Heavily Secured) home wireless network. Attempted to connect with correct key and with the unit added to MAC table. The device will scan, obtain an IP, Disconnect and then Disable the connection ("Disabled, Secured with..."). Signal strength is excellent.
-Restarted Tablet and tested.
-Removed MAC filtering, reboot and tested.
-Assigned an static IP address to the tablet and tested. back to DHCP.
-Changed Connection name and Password, reboot and tested.
-Attempted router cold boot and tested.
All with no success.
All of my other devices connect without an issue. After the weekend was over, I took Acer back to work, and it connected to my work wireless in the elevator on the way up with no issue.
Something I'm missing maybe? I havent run a factory reset, becuase I have it set up the way I need it and it appears to be a funtional unit.
