Help A70 has 2 phone numbers for me. Mine & Unknown One
jo69
Got a Samsung A70 works well apart from the fact I have an unkown number as well as my main number on my phone
It will not delete
Shows as Default in my profile
Doesnt work. But keeps cutting me off and trying to
Shows up in the QR Reader as me!
It shows up in SIM Manager. But my number doesnt!
Never had it before
Wont let me set my own number as default.
Contacted phone provider and Samsung.
Each blame the other!
Any ideas folks would be great.
hmmmmm well can you go to your provider and show them what is going on. it sounds like this must be coming from them, if it shows up after a factory reset.
I had something similar on an old blackberry. It was a cdma phone that also allowed for gsm. So verizon had a number connected to the phone, and when i inserted a sim card it still showed that Verizon number, so I went into settings and selected GSM instead of CDMA, and it then worked with my SIM card.
So if it is a CDMA phone that might have a number connected to it, go into settings and find a way to switch to GSM.
Thanks all for the help
The provider admitted my problem and after many phone calls, I now I have a new sim card with just the correct number!
