Root A87 Cover??
If you don't find anything, then try finding silicon case for Galaxy S2. The Length and the Width are almost the same. Not sure about the thickness!
Does galaxy s2's cover fit a87 perfectly? or its loose or too tight? I m asking because a87 has a curvy back..s2 has a flat back
i'm at chennai.. i bought it for 80bucks.. but i think its bettr to avoid silicon coz they wont let out de heat.. not recommended.. go for pouches..
