Help Ability to remove an item from Power Down Menu
Tricky37
Hi
I need the ability to remove the option to turn off the internet from the menu that appears when you press the Power Off Button. The phone is being used by a vunerable child in care and has various apps locked to prevent use and a gps monitor and tracking system installed. Unfortunately the gps tracking only updates the location if the internet is active and children being children like to avoid the tracking so turn off the internet. Due to the other locks in place the only place the internet can be disabled is from this menu. I am therefore looking for an option to either prevent the internet from being disabled or hiding/deleting this menu item.
I am a complete novice with Android, but can follow clear instuctions, I am more than happy to access the root if that is required, but i will need step by step instructions on how to do that.
Please can someone help
Regards
Tricky37
