Apps About dynamic slider
simple80
Hello,
I used a sample code is reading images from R.java file. I want to change it as display from web. But it has an error. Because i sent parameter is drawable but it must be Integer. How do i it?
Current Code
PHP:
                             image_prev = (ImageView)findViewById(R.id.image_prev);
        image_centre = (ImageView)findViewById(R.id.image_centre);
        image_next = (ImageView)findViewById(R.id.image_next);
        image_res_ids = new ArrayList<Integer>();
        image_res_ids.add(R.drawable.zero);
        image_res_ids.add(R.drawable.one);
        image_res_ids.add(R.drawable.two);
        image_res_ids.add(R.drawable.three);
        image_res_ids.add(R.drawable.four);
i want to change with this
PHP:
       Drawable image = loadImageFromURL("http://dedededede.com/image.png"));
       image_res_ids.add(image);
example is here
