about my android OS
  • Start date Start date
A
Android Question
Guest
unfortunately stops all....OS is corrupted....how can i repair it???
We'll need more information before we can help: what error messages do you see, for example. A detailed description of what's happening will help us identify the cause.
If the problem is a corrupted OS (i.e. if the phone won't boot - apps crashing is probably something else) then how to reload depends on what device you have. So you'll need to tell us that as well.
As a guest you can't respond to this. So you can either post a new question, including as much information as you can, or else you could register (it's free) and reply to this.
Good luck :)
