These aren't really items that you use such as an app. They are built in features that provide functionality to the phone.
A brief explanation of each shamelessly copy/pasted from the web:
Gyroscope
Provides the orientation (or attitude) of the device, it's much more accurate and reliable than accelerometers for this purpose.
Accelerometers
Provides the magnitude and direction in which the device is moving. As the name implies, it measures the acceleration along any given axis.
Can be used to determine orientation of the device if you use accelerometers along 3 or 4 axis, but is significantly less accurate and prone to errors.
Compass
As the name implies, it provides you your heading. It is aligned assuming you're holding the device face up and the top of the device away from you.
Input from the Gyroscope and Accelerometers allow for more reliable compass readings should your device not be oriented flat and face up.
Barometer
Provides barometric pressure to aid in determining your altitude. Knowing your altitude can speed up a GPS lock. I'm not entirely sold on the success of this yet, since barometric pressure is not a constant with altitude.
An example of everyday functionality using a couple of these features:
Proximity: usually a tiny sensor located next to the earpiece/speaker. When blocked, the phone display turns off. This is useful when making phone calls to prevent accidental screen touches from the phone against your face.
Gyroscope: Rotating the device allows the screen to rotate accordingly to the position you are holding the device in. IE: landscape/portrait.
Compass/Accelerometer/Barometer: Useful for accurate mapping/GPS/speed/etc....
