Root Accidental factory restore... HELP
julzdroid
I successful re-rooted and have been using my phone for months. Today my phone was accidentally restored to factory settings and now Google wont let me sign in. When I try to it says my user name and password do not match. I have even tried changing my password and signing in with the new one. Nothing is working. I had the superuser.apk installed.
So you have lost root?
Did you re-activate your phone over the air, first? After you tapped the Android graphic, the phone should have dialed into Verizon and prompted you to press 1 for activation. It takes about a minute, then says you're good to go and hangs up. After that, you are prompted to sign into your Google Account
Why not simply reroot and load the backup(i hope you made ) of the rom you were running?
You can also try removing the battery and replacing it. Helps with a lot of problems.
