Help Accidental Phone Call Issue.
Dimpyblue
I bought the S5 about a week ago, I like it but I'm have one major issue/inconvenience. It happens after I finish texting someone and I hit the power button to turn the phone off. For some reason it calls the person I just texted. It doesn't happen all the time but it has happened a lot in the past 24 hours. Has anyone had or heard of this issue before and does anyone know how to fix it?
Hi, I don't know if this will help, but if you go to "Settings", scroll down to ""Call", and at the bottom you should see End Calls By, if the "Pressing the power key" option is checked then uncheck it, if it isn't checked then check it. Phil
