Accidental set text format wrong
Hi,
My name is Brian Dando from Oswestry in Shropshire UK. I have a problem with my 10.2" Tablet PC, when I tried to read my book I inadvertently set it to be the default and selected one of the text formats and it turned out to be the wrong one and will not read my book. How can I reset it back so it is not the defautl format??????
Brian D:mad:
Welcome to Android Forums, Brian!
If you go to menu>settings>applications>manage applications and find the app that you are using as a reader and tap it. Then clear defaults. The next time you try to read the book it should prompt you for the format again and this time choose the correct one.
