wastelander
I recently rooted my lucid 2, and like the title says I accidentally deleted the smart share app. Does anyone know how I can get it back?
Is it possible for someone who is also rooted (stock rom I presume?), pull the apk and send it to him?
Yeah it would be nice if someone had the apk.I was just thinking the same thing.He could sideload it with adb shell.
i didnt know you could adb install a system app. learn something new everyday i guess.
Yes you can,I had to sideload my launcher after I deleted it because I was using Holo Launcher Pro.Then I had to do a factory reset and boom,No Launcher.All you need are the commands to push the apk..
well I had no luck getting the app back any other suggestions?
lgrootnoob's suggestion did not work? That would be the way I know how as I'm not familiar with adb.
His suggestion and adb would be the only ways to get the apk back.
Did you move the apk to /system/app, change permissions (to match the other apk's there), then reboot?
If so, what file manager did you use?
su -c busybox mount -o remount,rw /system
Oh damn, i forgot to reboot it worked. although I just noticed every time I try and open the app it says unfortunately smart share has stopped.
im guessing you didnt set permissions on it like on the other apks in /system/app
you might also need to remove the /data/data folder that goes along with smartshare.
get me a logcat and wipe dalvik cache too
what method did you use to put it back?
is it actually in /system/app now?
did you run into any errors while trying to put it back?
if you have trouble with permission denied errors use
Code:su -c busybox mount -o remount,rw /system
All i did was was move the apk into /system/app and reboot.
You can't just move it,It won't work.It has to be installed through adb.Which in turn,You will use command prompt on windows os.
