O OhLaLa101 Lurker Sep 29, 2012 #1 Accidentaly deleted SYSTEM folder on my crystalview EP-4/4858 and now i cant go on it what do i do?
StarScream2109 Extreme Android User Sep 29, 2012 #4 Best bet is to locate a stock ROM or another ROM and flash it
O OhLaLa101 Lurker Sep 29, 2012 #5 im trying but cant keeps on saying "E:Error in /sdcard/update.zip (Status 0) Installation aborted" for every rom
StarScream2109 Extreme Android User Sep 29, 2012 #6 You need to go to install zip from SD then select the ROM
StarScream2109 Extreme Android User Sep 30, 2012 #10 Okay hmmm...your rooted without CWM see if a dev can sign his ROM so you can flash it
StarScream2109 Extreme Android User Sep 30, 2012 #12 Locate him and send him a PM explain your situation he should be happy to help
StarScream2109 Extreme Android User Sep 30, 2012 #14 Best of luck sorry I can't be of to much help as I don't have your device
