Help Acclaim "hung" and is now stupid slow....
Five66T
This was odd as heck.....
Yesterday morning, my wife calls me. Pull my phone out and swipe the answer button. Phone stops ringing but doesn't answer. It then "hangs up" - not the call which didn't complete, the phone hangs. Not responsive, to anything. Phone is showing the lock code screen but doesn't respond to anything. I can't turn it off, I cant unlock it. Nothing. I stand there staring at it and in a minute or so (it seemed that long) it APPEARS to respond to something as the screen appears to unlock and it's on my phone log, showing the missed call. I try to select the number to call back. Again, nothing. No response, can't turn it off. Again after a minute it goes back to the home screen then nothing. So I pull the battery. Wait about 10 seconds, put it back in. It seems to take and extraordinary amount of time booting up (not that they are fast to begin with). But even once the lock screen comes up, it does not appear to have completely finished it's boot process. The EVDO icon isn't in the status bar although the signal strength meter looks ok. My Weather.com temp icon isn't in the status bar. I managed to complete the call to my wife and the EVDO and weather icons eventually appeared.
But since this episode, the phone has run VERY slow with seconds (4 or 5) passing between some screen changes.
Im pretty new to the Acclaim, that is all I can really think of. Hopefully it helps!! If I come across some more options or think of anything, I will be back to post!
I cant vouch for this one, as I have not had to try it but I read this somewhere....... "in the manual that it says you can do a reset for an un-responsive phone by pushing the Up Ringer Volume, camera and power buttons"
