How to update Accu weather update my galaxy s3 .When I press the update button on the home screen weather forecast is not update. please help me to solve the problem
thanks
Hello rajku and welcome to AF. Go to Settings > Location services > and make sure Use wireless networks and Location and Google search is on and see if that works.
Edit: Did you recently update your S3? I am actually having the same problem also, but if I come across a solution I'll be sure to share.
hello Metroid ;
The wireless network and google search are on .still it doesn't update the weather update.I have android 4.0.4 version.recently my provider reset the factory setting.
thank you very much for your reply. if you find any solution let me know
thanks
After turning off my device and turning it back on again it seems that the Acu weather update seems to be working now. I guess you could try that and see if you get the same result and I hope this helps.
