Accuweather widget probs and Task killer advice
ColinBH
Hi I wonder if anyone can help.
I have a Samsung Galaxy Ace 2. My accuweather widget does not change location. My HTC widget always found my location when I was on the move. I have enabled the current location setting and have auto refresh set to 1 hour but still nothing. Does anyone have any ideas?
Also,I have Advanced Task Killer on my phone. First of all, is it any good and worth having? second, what are the most effective settings to have it on? The auto-kill level I currently have it set on is 'disable', security level is 'high'.
Any help on either of these issues would be greatly received.
Thank you
CBH
I'm not too sure if it will help, but have you tried with your GPS on?
And for the task killer, it's a better idea not to use one in general. Here's a link EarlyMon posted explaining why task killers are bad/useless.
Android Task Killers Explained: What They Do and Why You Shouldn't Use Them
Free RAM = Wasted RAM :)
Hi, thanks for this. I will read the link and probably remove task killer if it is useless.
As for the other issue, yes I have tried it with my GPS on and it still doesn't seem to locate my current location.
any other advice gratefully received
Thanks
CBH
