Root [ACS][KERNEL][CWM][ODIN] LoStKernel Root/BB CWM5 Tweaks WIP ***10/13/2011***
chris41g
Finally out of beta... a public release.
LoStKernel does not claim to get RID of LoS, but it does significantly cut down on it. Over the past 2-3 weeks, numerous people have downloaded it, and I can say that it has had maybe a 5% reported LoS rate, and of those people, they had a significant reduction in the amount of LoS they had.
Now the kernel isn't all about LoS though, its fast and stable, and your phone will be smooth and snappy. That's the goal after all isn't it? something we can use?
There are 2 builds of LoS Kernel, the Standard build, and the Experimental Build. The standard build can always be considered stable, on the other hand, the Experimental build is where features go for testing before they are committed to the standard branch. Also, the Experimental build is cutting edge, overclocking the CPU 1400mhz and 1600mhz as well as Voltage control and Setcpu interface support. There is also Gpu O/C support. (Terminal command support only at this time.)
Both Builds are updated pretty regularly so check ACS regulary for updates...
Download from ACSyndicate.net
Checkout the Video by QBKing77 How to install the LoStKernel on the Samsung Epic Touch 4G - YouTube
Standard features:
Code:
Wifi Driver Fixes (Memory Leaks)
Conservative governor is default (Tweaked)
NOOP Scheduler is default
JHash3 Support
CIFS Support
Tegrak support
Touchscreen Lag Fix
DPRam Driver Tweaks
CPUFreq patch to address issue with second core forgetting min/max clock frequency
CPUFreq Bugfixes
Read Ahead Tweak
Sleep Death Patch
SU binary (Upgrade-able)
Superuser.apk (Upgrade-able)
BusyBox (Upgrade-able)
CWM5
init.d Support
Bootanimation Support
Plus Tweaks
Exp features:
Code:
Everything from the Standard branch
OC steps 1400mhz and 1600mhz
U/v controllable from SetCpu and Voltage Control
GPU OC
Tweaked Voltages
Minor Linux Version upgrade from .7 to .8
Cutting Edge upgrades from time to time
DO NOT USE TEGRAK WITH THE EXPERIMENTAL BUILD
I recommend Voltage Control or SetCpu.
to change the gpu clocking:
Code:
adb shell
cat /sys/devices/virtual/misc/gpu_clock_control/gpu_control # To view current settings
echo 267 300 > /sys/devices/virtual/misc/gpu_clock_control/gpu_control # Sets GPU clock from 160/267 to 267/300
Please report any problems or bugs in the Exp branch to #lostkernel on freenode.net
Now for thanks.. its a long list..
Code:
First off, big thanks to #samsung-epic-touch, #lostkernel over on freenode.net.. and #epic over on fossnet.info
naerok for hosting my builds when my host went down, Rodderik and insan|ty for dev-phone in general... rodderik helps me a hell of a lot.
ACS, is a great team of testers and we find ways to make things happen. who else makes kernels like this without phones???
Rjmjr69 makes things happen behind the scenes..
Bubby323 soon to be on a phone near you..
Nubecoder if he wasnt around to spot the stupidest shit i do, i wouldnt know what to do...
Nullghost great to have people i can ask for help..
Uberpingiun resident linux expert...
DRockstar how many phones you working on now?
Decad3nce so busy with CM7, surprised you havent said **** it with all the ungrateful people.. yet you still help out.
Entropy512 dont know you, but i used some of your commits..
Ninpo dont know you, used your commits, heard a lot.
Netarchy pretty much a kernel genius, used some of his commits
Shabbypingiun
k0nane
WR47HANZ
Tphillips
ptfmedic
qbking77 can you make a video for this?
cnz i dont care what they say about you.. your opinion may suck and be ridiculous sometimes, but you still say it like you mean it. and that counts for something
Testers: not all of them so if I left you out, MY BAD
Code:
lovinlissa1984
pyrostic
Drakhar
Orionstein
thefredelement
yourm0m1
art3mis
acrown
akarol
AlonzotheGreat
BLOWNCO
chunology
dtruong4715
ffolkes
fishfuzz
fordmanck
frifox
Geraldweb
imesg
jbn
Jeffy
JesterCorp
kudakeru
lballer69
Leodoc
Mantis
Orrkis
PhantomPhreak53
platinumj
stangdriverdoug
especially that guy that said only shitty developers code on the touch.. you inspire me daily.
And Please remember, I do not own this phone... so before you ask me a question, think about whether or not it's something I could possibly know without having one in my hand...
My Projects
There is no quid pro quo, I only put this button here because I was asked to.
Don't donate because you feel obligated or because you think I will feel obligated.
My work will continue regardless. All donations are appreciated none-the-less.
Please forgive me if I am asking a stupid question, I am a noob, & an ignorant one at that! I rooted my Samsung Galaxy S2 Epic 4G Touch/SPH-D710, running 2.3.6 Gingerbread.EL29. Now I have touch screen lag, battery drain, loss of service, & general quirkyness. My question: WILL THIS KERNEL FIX MY POOR PHONE? Any help is greatly appreciated! Thanks.
May help but is outdated. Need some more info to try to help you better. Like how did you root? Running a stock or custom rom? Any other mods installed?
K thanks. There are a few good kernels by team rouge for gb roms. They have the Los patch in them. As far as battery life goes its probably a rouge app. Several different ways of tracking it down but I suggest getting better battery stats from either xda(free) or on the market(paid). Also grab cpu spy from market as well, its free and will tell you what frequency your phone has been running at. That should get you started for now. I have subscribed to this thread and will be checking it.
"team rouge for gb roms"??? Sorry, I am a noob! I have no understanding as to what that means, again, I apologize.. Could you please explain so that the new village idiot, ME, would understand? If not, I understand. Are you saying there exists more current code to fix my poor phone?
Lol we all start somewhere at some point right? I know I did. Actually I need to retract what I said earlier about team rouges kernels because I forgot they yanked them over something but chris has a great repack el26 kernel that should help you out. All repack means is that its a stock kernel that has cwm(clockwork mod recovery) added to it. It is more current than the los kernel here. You could always try this kernel as it may suite your needs. I will edit this post with a link for the el26 kernel. Any specific questions just ask, I will do my best to explain.
Here is the link -
http://forum.xda-developers.com/showthread.php?t=1416056
Hey Rounsy222, I read all 7 pages of forum.xda-developers.com thread that you linked and I watched the QBKing77 how to video. My only question is the kernel is EL26 and mine is EL29. Is that a problem? What is the difference?
El29 is a slightly newer build (3 days) and el29 is official build while el26 was a leak. El26 is the fallback kernel that is used from coming back from an ics rom so it is a proven warrior. And if I remember correctly you seem to be having issues with your current setup and was referring to swapping to the Los kernel and this would be a suitable upgrade from it. Make sense?
Absolutely! Thank you so very much. I going to do this and hopefully stabilize my poor phone. I am learning! Will let you know how it turns out.
