Help Activating Hot Spot option on unlocked S2?
I had my S2 unlocked by AT&T when the contract expired (I moved to a Note 3). I have used the S2 internationally with local SIMs for phone calls and 3G access without problems. However, I recently tried to use it as a hot spot and received a message (I don't have the exact wording) saying that either my phone would not work as a hot spot OR the SIM could not work as a hot spot. I tried the SIM in a friend's phone and it worked fine as a hot spot. So, it appears to be the phone. My S2 has the menu options for working as a hot spot, so was I doing something wrong or is there a problem with using the Skyrocket as a hot spot?
