Help Active Calls
A
_android9k_
Guest
Hi,
Just got an Ace, been making a few buisness calls to companies with the usual menu options....Im getting v.poor screen response when trying to choose the required option key...the voice on the menu feature justs keeps rambling on and activating required number choice on the keypad is ignored? I have a feeling there may be a tweak for choosing options on given menu calls....when I choose for eg option 2 Im also getting a save to contacts bar which does not seem quite right, anyone know if this is my error?
Just wondering is this a rampant behaviour with Android Touchscreen devices or should I post the phone straight back to my provider?
Addon: Now only two days after purchase I have been unable to get a network connection for any outgoing calls and incoming are being redirected to voicemessage with user unable to answer? Hope charges are suspended?
_android9k_
Check with your dealer... i have used it for many conference calls and otherwise but haven't had any problem.
