Lana30 Android Enthusiast Aug 12, 2015 #3 El Presidente said: Impossible, sorry. Click to expand... awww, really?
El Presidente Beware The Milky Pirate! VIP Member Aug 12, 2015 #4 To use ADB, USB debugging needs to be enabled so you can't use ADB to enable something that is required for ADB to work in the first place.
Lana30 Android Enthusiast Aug 12, 2015 #5 El Presidente said: To use ADB, USB debugging needs to be enabled so you can't use ADB to enable something that is required for ADB to work in the first place. Click to expand... Makes Sense, thank you.
