Rafalema
Member
Hello..
So I've made some mods to the framework-res.apk, and I'm now trying to push it back. However, everytime I try to push it, the comp thinks for a while and then reports
"failed to copy 'framework-res.apk' to 'system/framework/framework-res.apk' : Directory not empty"
This is what I input when I get this:
"adb push framework-res.apk system/framework"
I've also checked my internal phone memory- 49.12mb left so I don't think I'm really out of memory.
And for the sake of it, I should mention that whatever application I pull/want to push, I need to put it to C:/Windows/sysWOW64/ to get the commands to work.
I'm on W7.
I know I could just mod the rom and reflash it, but I don't like the restore process.
Also it shall be put out that I did a .zip file with modded framework, camera, contacts, and phone app, I edited both the signing-files and the installer script files to match my needs. After I flashed that however, my camera, contacts, and phone disappeared and framework was normal as usual. I did a full restore from recovery.
Any ideas?
Thanks!
I'm on W7.
Any ideas?
Thanks!
