Lana30
Hi Friends,
If after entering the appropriate commands you get a message that says that all commands have executed successfully, but the phone is still not unlocked (not from carrier unlocked..the other unlocked when trying to get into your phone since you can´t access it through the display), will turning off USB debugging and then turning back on help? If not what will? Thanks.
[Cygwin still does, though
