I would assume they are, b/c I use my computer to put files on my sd card via usb cable, mount/unmountDid you install the samsung driverS?
no, whats that going to do?have you tried using testmode( send + central button + end ) to see it works?
so if im in usb debugging mode, & the phone wont let me mount, then i dont have the right drivers?That only means you have the drivers for usb mount installed. One way to check to see if you have the proper drivers is to enable usb debugging, and then try to usb mount. If it doesn't work, you don't have the proper drivers.
